A/C Rotted My Frame. .
    Hey there guys I just wanted to ask you guys a question. When I bought my 89' MGM the car looked impeccable for 20 years in our Canadian climate. Hardly any rust but when I took the car for a oil change I saw that the frame on the front passenger side just after the door is a nice chunk of frame gone. Every where else looks great but right there. Now I also knew another guy who has the same car and he says its the way the air conditioning when it spits out the water it drips into a little hole in the frame and runs down there and collects causing it to rot. Thats what happened to his but he just welded it up just wanted to know what you guys think thanks.
    Very, very common problem.
      yea, very common. if you can get someone to weld in a patch, you will be all set. just get your car undercoated and you wont have issues.
        hahah got love these car. So I guess ill go look around for a shop that can do that.
          Good thing my AC doesnt work. LOL
            try sticking to having a repitable welder or frame shop do it since you want it to be strong and look half decent.
              My frame rotted on the opposite side, go figure. Frame is fine under the AC, don't ask me how that happened.
                I had frame rot on my 81' (that I did get fixed) back when I had it.
                That car was a non-A/C car though?!?
                Former panther owner
                1981 CV 351 4bbl
                1991 CV 302 EFI
                  Makes me wanna have mine checked out.... I have no idea where to look. My ac probably hasn't had anything in it for the last 19 of it's 20 years though
                    also im told that these car like to rust from the inside out?? so if i fix all the rust on the out side and fresh paint. Will I still run into problems. Thanks
                      rust never sleeps
                      you gotta do your best to keep the body drains open and free from debris, washing the dirt out of the door jambs and the wheelwells and under the car helps.......if the car is already rotted away completely, theres not much you can do
                        yeah, the rust in your frame is starting from the inside of the frame. Your best bet is to go overkill on welding it all up (in area, not thickness of metal) and the undercoat the hell out of the interior of the frame through every access hole you can find. Poke and prod ALL the metal around your hole. I though I had a 2-3 inch hole, and after a few minutes with a screwdriver I had 2 4-5 inchers.
                        I should really edit that paragraph to sound less homosexual.
                          My 87 has some surface frame rust/rot, passenger side but its pretty far back...could be A/C? As of now it passes inspection because the guy that inspects it knows me and that I just use it as a cruiser/toy and its not very serious yet.
                          -2004 Crown Victoria Police Interceptor - Daily Driver - 17" Bullitt's, 235/55/17 Goodyear Eagles, Ex-NH State Police, best 1/4 mile time; 15.3 @ 90 mph
                          -1987 Crown Victoria 2-Door - Project - 90k miles, Summit chambered muffler, Sunpro gauges, parked since 2010, fate tbd
                            My 92's driver side's frame rail has is completely rotted away from the rear door up and separated from the bulkhead?. The car is so bent now. Rust is terrible.
                              see now thats my problem I can't restore the car knowing that there is always some thing in the frame that is eating away and one day ill just have to junk it. Let's say I spend X amount of money on the car every thing is mint but inside the frame where know one can see is just eating itself then like pantera77 said car starts to bend. I guess thats just the way it goes
