Rear window trim removal
    How do you remove the outside rear window trim so that i can remove the the little bit of vinyl roof that is there?
    NA-15.78@91.21, 80hp shot-14.48@96.21
    With a window trim removal tool.
    Disregard the wood trick. It is not necessary for our type of molding.
      Those tools are a lifesaver, Ive got some for the interior panels too, well worth the $20-$40 dollars a set. Never have a broken pin or cracked panel again.
      1985 GMC 1500
        Got a video of the tool to get the lower trimpiece off with those funky plastic pushpin things?
          No. Those just break, and break often. I was with Scott at a JY one time. I handed him a little flat head screw driver and a couple of minutes later he came back with a handful of unbroken ones. How he did it? I will never know. I just broke most of the ones I tried removing.
            Those trim tools are pretty easily cut out of flat stock and bent up. Save yourself the money and have the "cool" (by which I mean nerd) factor of having a home-made tool.
              I just used a flat-head screwdriver for mine too didn't break any either... they make a sickening POP sound when they release. When re-installing, put the clip in first, and you have to push HARD to get it to snap all the way back into place, or the trim wont sit all the way in.
              I replaced my colored trim with chrome
                what was the technique using the flathead screwdriver?
                  I just stuck it in there between the top and the trim and pried away from the glass until you hear an 'omg i just broke something' caliber 'pop'
                  That top is already cracked up so i wasn't worried about hurting it, but it didn't seem to mess it up anyway.
