taking off side light lense?
    i'm going to switch out the bulb in that little 1"X6" light on the side of the car with a real pure white LED instead of the amberish light.
    just wondering how to get the lense off without damaging anything
    They should just pop right off with a screwdriver iirc ....I liked the amber..it gives the car and Ol fashioned look...
      Just to clarify you are referring to the exterior B pillar light?
        if your talking about the B pillar coach lamp then, the 2 chrome peices pop off to expose a phillips screw on each side then the light comes right off. i recommend a skinny flat to remove the chrome end caps so you don dammage em...make sure you get pics. i use blue bulbs and it gives off a light greenish glow, looks cool but id like to see how i can get the limmo coach light effect
          OH yeah...I forgot about the screws...LOL...My bad..its been a while..My Vic Dosen't have those..LOL
            ha thanks boys.
              Anybody done this on a box Town Car? Screws or no screws? It appears to be a snap-in, but I haven't looked too carefully yet.
              My driver's side lens has a hole.
                towncars might be accessible from inside... the trim is different... i have white LEDs in my B pillars of my Grand Marq.
                Addicted to 86-87 Panthers
                  I think Town Cars are accessible from the inside. They sure as shit ain't from the outside. I fucked mine up figuring that out.
                    I thought the Marquis's coach lamps were accessible from the inside? I had to replace one of the bulbs when I first got the car, and I remember taking off the interior of the B-pillar around the seat belt with the two-three screws on the top and bottom of the piece?
                    I don't think I've ever popped off the chrome...
                      on mercs, you can access the bulb from the inside but its less of a cluster fuck if you do it from the outside. how do they look with the white LEDs? the give off a blue color, no?
                        Good to know. I've got a set of red LEDs waiting to go in...
