Need front facia 93 GM what else fits?
    93 GM needs complete front facia (bumper, bumper cover, headlights, grill) and radiator support. Junkyards say only 92-94 will work. I am only intersested in the front end to fit correctly and lining up to fenders and hood latch. Will other years work even though the styling is different?
    The '92-'94 parts would be ideal but '95-'97 GM parts should fit as well...
    '79 Continental Town Car
    '90 Crown Victoria LTD
    '94 Crown Victoria
      I dont know if the 95+ would work real easily. Look on Wikipedia under "Grand Marquis" theres a picture of a 92-94 and one of a 95-97 they look pretty different. The grills, bumper covers, and running/turnlights are completely different, so you cant interchange piece by piece. The bumper itself and radiator support are probably easily interchangeable. But if you were to find a donor 95+ you could probably swap the entire front end (fascia, fenders(?), bumpers). Otherwise go to a body shop and ask them this same question.
      1998 Mercury Grand Marquis 131k~ true duals, 2nd cat removed, H-pipe, Xcelerator Turbo mufflers, PI Manifold, 180* Tstat, K&N drop-in.
      1985 VW Vanagon 70k~
        this.
        You can't mix and match between the two, but if you are swapping everything in front of the fenders, the 95-97 will fit.
