well i'm continuing the removal, shaving and adding and removing things trim wise...the initial just the bottom trim became the bottom and middle trim to custom moulding removal and fill and then some resto-mod and factory restore...so here is some more of the goodness that is happening on my Panther
well this is one of the many things that were painted over...used to say Speed Demon all together
after disassembly and assembly to correct some malfunctions and all cleaned up together
after cleaning and slightly polishing the runners and trim
a full shot today...didn't get much in-depth step-by-step today because of time crunch...but u can get the just
don't mind the top line...theres where i'm starting tomorrow...but the rest is glass smooth
so theres todays achievements after a 1-5AM visit to the ER with my Fiance, then a 8:45am OBGYN Appt and a day full of running around fixing my buddies van and working on my car...throw some ideas and wat not at me...
FUTURE - CAR WILL BE GOING SLICKTOP
took me a while to finally decide...but for sure...probably next spring/summer and will have to let my buddies shop do it more than likely...i want everything welded instead of bondo
