Originally posted by 1990LTD
View Post
mounting foglights
here are mine I mounted them under the bumper I had to drill in to the bumper. I have an extra set just in case I have them running off a relay
i would use a relay system myself. tap it into the parking lights, that way they will shut off with your lights and you can have them on with low, high, or both. it also lets you turn them on without turning on the low or high beams, and it will still ding when they are left on.
just my 2 cents worthWhat happened here?
Originally posted by Brown_Muscle View PostTry ebay, thats where i got mine for 41 bux shipped...was ment for a newer style vic like yours too..but I improvised
This is the style I wantsigpic[LIST][*]99 Crown Vic Police Interceptor aka The Cruiser
[*]87 Chevy 20 Van 350TBI
[*]94 Mercury Grand Marquis aka Babyblue RIP
[*]83 Chrysler New Yorker 5th Ave 318 V8
Originally posted by gabegt90 View Posthere are mine I mounted them under the bumper I had to drill in to the bumper. I have an extra set just in case I have them running off a relay
now tahts how i want my GM to look. i have the wheels, but need paint.
and to add to the thread, mine are mounted behind the grille, they are mounted ot a couple pieces of flat stock. i am not sure exactly i just wired em up but the PO installed them.
My 85 had a thin bar running behind the grille... i mounted mine there with some big 'L' brackets. They vibrate a tiny bit and cause a flicker where they are even with some bracing... so I will probably wind up moving them to where Dave and others have them.
