Where do the tranny cooler lines actually go into the tranny? Is it possible I already have a factory tranny cooler?
front end removal
oh, ok. Thanks.
Originally posted by hav24wheel View PostI just installed one on my 83m. Just took the grill off, and it was easy as hell. Lots of room t
O work with. Can't be that much different for yours.sigpic
Bah, I did mine with the grill on... Just slide your hand up in there.
Plenty-o-room
Easy Peasy Lemon Squeezy...2000 Grand Marquis LS
Mercury Owners Group member
I'm pretty stoked to install this. It sounds like it'll be fun...I'm wondering about the return line though, which is which? Am I gonna have to stick a container under it to catch fluid when I disconnect it to plumb the cooler in there?Last edited by 1990LTD; 09-24-2009, 03:29 AM.sigpic
I believe the bottom outlet of the radiators stock cooler is the return...~David~
The fluid loss will be negligible.
Are you running in series with the stock cooler or stand alone?
My theory may have been wrong, but I ran through the cooler first then through the stock radiator cooler.
Thought being that 'if' it is very cold the fluid could get too cold and by running through the radiator cooler second it could warm it up if needed..2000 Grand Marquis LS
Thought being that 'if' it is very cold the fluid could get too cold and by running through the radiator cooler second it could warm it up if needed..sigpic
A guage with a switch to run it through the cooler only if hot would be ideal...2000 Grand Marquis LS
That's a neat thought. Would help keep it from taking too long to warm up. Is that difficult to implement? If not, I should consider trying to do it on my car since it still has its old auxiliary transmission cooler.2012 Mazda5 Touring | Finally working on the LTD again!
Originally posted by 1987cp View PostThat's a neat thought. Would help keep it from taking too long to warm up. Is that difficult to implement? If not, I should consider trying to do it on my car since it still has its old auxiliary transmission cooler.
Wouldn't be hard, but would have to be custom built, doubt there is a kit...2000 Grand Marquis LS
Originally posted by 85MercPark View PostA guage with a switch to run it through the cooler only if hot would be ideal...
I think the "staked plate" coolers work kind of like a thermostat... the warmer the fluid gets, the more of the cooler it uses.Last edited by hav24wheel; 09-24-2009, 09:59 AM.sigpic
running in series.sigpic
I must be fucking retarded..I can't get the grille off. It's not screwed on, it's held by clips, I think, but I (nor any other human sans double-jointed arms) can't reach them.sigpic
