Do I own a LTD? And how to get off glue?
    How do I check to see if my car is a LTD? I saw a pic of the interior dash badge for LTD's and it looked allot like this glue silhouette I have on my dash. First, I was wondering how I can tell if my car is a limited, and also, how can I safely get the glue off the wood? I tried to wipe it off but it just smears.
    88 MGM 5.0 stock
    LTD didn't really mean "Limited" in the Ford lineup for a long time, it was basically a model name applied to what used to be a Galaxie back around 1970, and the name stuck. From '79 to '82, the base fullsize car was just called "LTD", with "Crown Victoria" referring to a particular option package that included the little tiara-looking wide band on the roof (similar to the "Crown Victoria" option package on the '50s Fairlane Victoria). For '83, the compact Fairmont got a facelift and was renamed LTD, so all the fullsize cars started being called "LTD Crown Victoria" regardless of trim level - in this case, not an option package, but an entirely different car. After the baby LTD was killed off for the '87 model year, the "LTD Crown Victoria" monikker continued on another few years until I think 1992 when the LTD part was dropped and Ford's biggest sedan became known as just plain "Crown Victoria".
    So the short answer is, LTD was not a fancy option package of the Crown Victoria, but in fact in the earlier years of the Panther chassis it was actually the other way around.
      In order to help you figure out this very complex question, I've constructed this easy-to-use flowchart. Hope it helps.
        OMG Bwahahahaaaaa!!!!!!
          Nice chart.
            Thats amazing.
            1984 CV tudor 351W, 4bbl, 5-speed best time in the 1/8 8.39 at 80 with 1.80 60ft time.
              leave it to the engineer lol. My boss (he's a mechanical engineer) made this huge excessively complex flowchart to determine what time it was from the GMT clock.
                Okay thanks, I have a MGM so its not a limited. But whats up with the square outline on my dash? And how do I get the glue off the wood panel? Thanks.
                88 MGM 5.0 stock
                  Where is it on the dash? It could very easily have been something that a previous owner glued on there and later removed. I've had good luck with products like 3M Adhesive Remover for getting glue residue off, but you'd want to test it on an inconspicuous area first to make sure it wasn't going to damage the dash.
                    colony park badge is there iirc
                    btw the ltd came out in 1965
                      Colony Park badge on the dash? And on a sedan? :p
                      How late were they putting those "Ride Engineered" plaques on the dash of the Grand Marquis? Suppose it's also possible it just said "Grand Marquis", but I know little about the later models.
                        silly nate nice chart though nate
                          not 100% sure...
                          I think '87 was the last year for the "Ride Engineered" plaques.
                          '79 Continental Town Car
                          '90 Crown Victoria LTD
                          '94 Crown Victoria
                            I love the "Ride Engineered" patch. For some reason, that was one of my favorite things about the car.
                              It was either Ride Engineered or Grand Marquis.
