Hey guys. I have some yummy rust that's turning into rot right where the rear passenger's door bolts to it. Rusting at both hinge mounting places. So my question for you guys, what can I do to repair it cheaply if possible?
Rot on the B Pillar
picsGive a man a fish and he will be fed for a day. Teach a man to fish and he will promptly forget that he once did not know, and proceed to call anyone who asks, a n00b and flame them on the boards for being stupid.
sandblast that stuff
Remove all the rust you can then see what you have to work with.~David~
I need pics to be able to tell you anything for sure. If you check out the thread for my LTD, I have pics of where it is just starting to rust on the bottom hinge mounting point of mine, inside the B-pillar behind the hinge's mounting plate. Not the easiest area to fix.
yeah I have that same area except it's in the front lol
Originally posted by LTDMan83 View PostI need pics to be able to tell you anything for sure. If you check out the thread for my LTD, I have pics of where it is just starting to rust on the bottom hinge mounting point of mine, inside the B-pillar behind the hinge's mounting plate. Not the easiest area to fix.
Originally posted by 86VickyLX View PostWhich page is that mang, my dial up hates pictures.
Just starting to rust on the bottom hinge mounting point, behind the hinge's mounting plate. The top was not quite as bad, but much harder to access.
The Cause. Water leaking down into the B-Pillar. It would also rust out the section where the B-Pillar meets the Rocker Panel, eventually as well. I have to find and stop the source of the leak, before I fix the rust, or it will be back again.
