I really want Lincoln mirrors with the floating thermometer in 'em.
Yea they are pretty cool!
Well if the screw holes line up and i can actually get a set off a box townie (i say IF because every set i encounter has the screw rusted to all hell in the bracket so i stripped the heads ) Maybe someone will have a drill ay SF09 i can borrow?
hey i just noticed that Town Car mirrors have studs embedded withing the mirror and a nut that you access from the inside! Which means it will be easy for CheeseSteakJim to see if Town Car and Crown Vic mirrors are the same size and that also means that they are super clean looking on the body! !!!!
I think the studs are probably set closer together than the holes on a Vic, but as long as the mirror covers the stock holes, drilling new ones isn't really a big deal.
I pulled out one of my old Vic mirrors. I gotta find one of my extra Town Car mirrors but with that photo refreshing my memory I'm going to guess that the Town Car mounts are vastly smaller... something like half the length, which means holes will need to be filled in and painted over.
A Town Car mirror swap would be fairly straightforward on a Vic though. Town Cars have power vent windows and the required shit for that inside the door makes removal and installation of one of the two mirror bolts a task suited for a contortionist with a lot of patience. It took me probably 20 seconds to take one bolt off with a 1/4" ratchet and an extension... the other I had to do with a combination wrench and it took me probably around 15-20 minutes per side.
I think I have my extra mirrors in my car's trunk, but it's up on jackstands without a battery so while getting the trunk open isn't difficult, getting it fully closed requires a battery because I have a luggage cruncher. If tomorrow isn't rainy and shitty, and provided I remember, I'll dig through all the parts in my trunk and see if I can find one to compare mounting sizes and mirror glass sizes to.
EDIT: oh, if it matters the Vic mirror I have is a power unit off of my old '90.
