rocker panel repair
    rocker panel repair
    found out that my inner rocker panels were rotton away and need to replace
    the whole side on both sides what a pain this is gonna be so thats why i havent had time to finish my tailgate.theres a 6"X 72" piece that runs the whole length of the car from front fender to rear quater panel.since this is my daily driver ill have to do section by section cause of the floor is welded
    to it and most of the floor there is rusted to and as i go along i can get all the rust off the top of the frame'sides the places that are covered by the floor and use the eastwood encapsulate to seal it and have new metal floors that are rust proofed i sure do hate rust
    Holy crap man. That is really gone. At least you are experienced enough to deal with it. I enjoy all of your repair threads.
      Shit!, dude.
      That is a huge mess that you have on your plate there.
      Gonna make your own patch pieces, or cut off factory sheet metal pieces from a parts car?
      Good luck with it.
        wow, thats ugly. Are you in upstate New York or something? Usually only cars from up north get that crusty.
          Gonna make my own patch pieces,im from westchester ny 45 mins north of manhattan. they go grazy with salt during the winter here.i pluged the hole where the inner rocker panel starts to be conneted to the body under the front fender the i encapsulated it and then seam sealed it. now i have to get all the rust thats on the inside rocker cleaned so i can rust proof it. i made a 7"x24' panel for the inner rocker that will run the whole length of the car like i said before this is my daily driver and i wish i could of do a 80'' panel but thats to much down time so section by section. every panel gets weld thur primer then welded up then encapsulated then painted i do not want to do this again.
            What are the Bulk-Heads on that thing lookin like? Have you removed the plugs and felt/looked inside of them?
              x2
              Current Rides
              67 Cougar XR7
              97 Mountaineer 5.0
              03 Ranger XLT
                Whats a bulk head?
                  bulkheads are where the frame meets other frame that goes toward engine bay and where bodymounts are located. they arent that bad dose need some work
                    ah thanks.
                      wow nice work
                      replace those nasty fuel lines while the weather is good
                        The bulkheads look savable, if you take care of them soon.
                        Nice shot of the inside of the bulkheads, btw. I tried to get that same shot, but my camera was too large to fit through the access hole, lol.
                          got inner panel in today and put floor section in and encapsulated it when that dries put some paint and the dynamat. the fuel lines are all gonna get
                          switched over to dorman high press fuel lines no more metal lines.this is the best way to go cause all newer cars have them so why not change
                            these fuel lines come in 10' lengths
                              got to the front of the passenger door with the inner rocker and the big pain will be where the wheel well joins the inner rocker got to find all the spot welds and hope its easy to get to
