I've been thinking about shaving the door handles on the car. Any thoughts, or criticisms? Obviously this a down the road project as the car has other needs first. My thinking is that the paint is shot, so if I do it I'll do it before the gets painted. I will be farming out the work as I will have them wire up an alarm/keyless entry system. Might as well get it all done at once so I'm not fucking with multiple remotes and multiple wiring setups.
To shave or not to shave
What happens when you get a dead battery?~David~
Originally posted by 87gtVIC View PostWhat happens when you get a dead battery?
Go shave ya dirty hippie! Get a job while your at it!
Oh... you mean your door handles... Um, well if you really want to...Owner of the only known 5 speed box wagon with a lift kit.
Axle codes
Open/Lock/Ratio #
G / H / 2.26
B / C / 2.47
8 / M / 2.73
7 / - / 3.07
Y / Z / 3.08
4 / D / 3.42
F / R / 3.45
5 / E / 3.27
6 / W / 3.73
2 / K / 3.55
A / - / 3.63
J / - / 3.85
Originally posted by Grand_Marquis_GT View PostIt's a good idea.
And remove that coach roof while you're at it
Since I'll be adding a boomerang antenna, I'll be shaving the power antenna. Fuckin' things broke anyhow. It's floppier than Burt Reynolds hopped up on Viagra.Save a seal, club a liberal.
Originally posted by Paul_ View PostIt's floppier than Burt Reynolds hopped up on Viagra.
:lol:
I would not shave them because the box LTD has some large slab sides and the missing door handles would just make them look huge.
how bout box townie door handles? they mount flush
Originally posted by lincolnmania View Posthow bout box townie door handles? they mount flush~David~
anything can be installed......would need some donor sheetmetal from some towny doors or any of the many 70's cars that had the same handles
