My '89 Grand Marquis was involved in a hit and run many years ago, someone backed into the right front door in a parking lot, and took off, dented the door up pretty bad. The car was parked not long after that, and has just sat with the dented up door for like 12 years now. I am working on getting the car back on the road for my grandparents to drive (they bought the car brand new) because they want to keep the mileage down on their '05 F150.
Anyway, there is a '91 Grand Marquis in the local Pull-A-Part that is the same color (or damn near it) with the same side trim on the door as my car has, so it would be a perfect match for the car from the outside. The only thing different, is the interior door panel. It's has blue interior on the junkyard car, and the panel is a totally different style then in my car, which has more of a maroon-ish colored interior. Will my '89 interior door panel swap onto the '91 door without any problems? And as for the door itself, I assume it will bolt on with no problem, but what about the wiring for the power window and locks? Will it be plug and play?
Thanks!
Thanks!
