Behind Grill Lights
    Behind Grill Lights
    I want to put fog lights behind my grill but i dont know wht type to use...does anyone have any suggestion....My car is a 90 CV
    get dual one peice fog and halogen lights, they are perfect since its always hard to decide!lol
      ok..cool, thanks man...Any idea on where to get em....J.C. Whitney ?
        That's why I replaced the stamped connectey thingy behind the grille with a nice piece of angled aluminum .......
          I have some going into my vic, actually.
            I just did this on my, currently my brothers 90 CV. I used a clamp on bracket, as I dont like drilling through things on the grille. this is the bracket that I used. http://www.pmlights.com/products.cfm...Id=14&pId=1754. just remember that lights get warm/hot and plastic does not do well with heat. I prefer a fog lens, but its your call. your grille will throw shadows , but its not that big of a deal. depending on what type you get, look at the drain holes if its not a sealed beam, they will collect water otherwise, and mount them correctly. I had a set of 100 watt spots behind the grille and they always collected water because they were mounted sideways. I have some pics of my lights on my 90 CV if you would like a reference.
            What happened here?
              yeah pics would be helpfull since my car is a 90 also...thanks man
                would these work.......
                  Any fog light will work, it just depends how you mount them. My 85 had a handy bar to mount the fog lights to behind the grille, the 91 doesn't.
                  Check your local laws too - you might be required to run a fog lamp that is DOT or SAE approved for state inspection.
                    OUCH those are expensive!! My eyes! My eyes!!!
                      go to junkyard and get the bar that mounts behind the grille to mount the lights to... with the bar, you can have a place to mount the lights. the bar gets mounted on lower area behind grille and good place to mount lights.
                      Addicted to 86-87 Panthers
                        This is a wierd kawinkydink that this thread was created on Sunday because I saw a box MGM with grill mounted fog lights on the way home from Pep Boys. I thought they looked pretty good and they weren't that bright. The guy hadthem aimed so that the light hugged the ground. I'm thinking that I might eventually do this myself.
                          Originally posted by chitownvic View Post
                          those look exactly like the $20 ones you can get from wallymart. whatever you get just make sure it drains properly. it is advisable to get dot/sae approved lights. it will be molded into the glass, most states require it, and if it doesnt have it, some states make you put covers on them. that clamp on mount works really well too, you can put it anywhere you want, just use a little locktight on it. its easy to move the lights for aiming. I will try and get some pics later today or this week.
                          What happened here?
                            Piece of angle aluminum is stronger and you can get it at Lowe's.
                              how would that mount behind the grille? i thought about that, but it doenst seem possible on a 90
                              What happened here?
