Originally posted by kellen302
View Post
Door window weather stripping
Helps if you put some lube on the back side of the new rubber and run the window up and down to help pull it in. Soapy water will get it done, doesn't need to be anything special. I pulled the door panel and worked from inside the door to get it pushed all the way down into the channel.86 Lincoln Town Car (Galactica).
