The weather stripping around the windows onthe doors has become dryand brittle, I went to autozone to see if I could buy new one or have them orderd and they said no... Besides a junk yard is there any place to get new ones.
Door window weather stripping
http://www.jcwhitney.com/autoparts/P...atherstripping
Ford no longer makes them, in fact people have been loking for them for years. I was lucky enough to be the last person to purchase a drivers side window run channel for my two door. But have no fear the link above should solve your problems. A fellow GMNr (well resident moderator: GMGT) used iirc style #20 for his two door MGM. If you go this route, well it is the only route you have, please post up the results because i too am in the market for the same thing only on the passengers side door.Last edited by 87gtVIC; 01-14-2009, 07:03 AM.~David~
the channel strip all around the window, and the one that sits on the door panel and the one on the bottom of the window on the outside. when i roll my windows down and stick out my arm it broke the outside strip and now water goes through like crazy. its that way on all the doors. i was hoping there was an alternative to these that you could buy.
Definitely Style 20, eh? I had thought 22 looked more like it, but you would know.
No difference between different bodystyles, I presume (hope?)?
I eagerly await information on dew wipes .....2012 Mazda5 Touring | Finally working on the LTD again!
Originally posted by taylorendicott View Postthe channel strip all around the window, and the one that sits on the door panel and the one on the bottom of the window on the outside. when i roll my windows down and stick out my arm it broke the outside strip and now water goes through like crazy. its that way on all the doors. i was hoping there was an alternative to these that you could buy.
We have been through this a couple of times, and yet cannot come up with a definitive answer to which style (dew wipe) will do the job. I am sure we are all in need of this information. In order to accomplish this on your car you will have to remove the door panels, remove any screws retaining the metal trim in place; remove the assembly and the remove the staples retaining the fabric to the metal trim. Then I can imagine you measure the old to the newly ordered and either rivet or re staple the fabric dew wipe back. If you go thorough with this in a well documented manner I am sure this will be sticked, due to the ever wanting of information regarding the topic.~David~
Originally posted by taylorendicott View PostI assume the window channel just slips into the metal channel in the door or does it glue in, this is all new to me.
And what you call the dew wipe is there nothing to replace it or maybe something you can use to fabricate one?
Here you can see the assembly still attached to a door.
This is the link to replacement dew wipe material. this is the closest you are going to get. You are not going to find the entire assembly (metal and fabric) anywhere.
Originally posted by 87gtVIC View Posthttp://www.jcwhitney.com/INNER-AND-O...3814_10101.jcw
Originally posted by taylorendicott View PostOn the jc Whitney web site they have a page for inner and outer belt weather strippingcould that be the dew wipe on the bottom of the window or Is that something completely different...
We gave you all the information and the links you need. Now you just have to choose which styles you think are going to work.~David~
Oh and to make it interesting here is a picture of the Drivers side window run channel i have.
