Where can i get ford paint? I need to fix a spot of rust and want it to mix in properly.
Where to get ford paint
Are you talking about the small touch up bottles, or like a quart of paint? The small touch up bottles are available from Ford... however, it is the same paint as the duplicolor... And if you need anything like pints or quarts... go to a body shop supplier... They can match your paint perfectly... (except for paint fade, unless someone there is good at doing a color match...) Most of the Ford body shops buy their paint from body shop supply companys... Since most of the cars are painted at the factory with paint from say, PPG.... So they buy that brand name from the body shop supplier...
I ordered touch-up paint from http://www.paintscratch.com/. They weren't overly expensive, and they give you all the info you need to get the correct color. Usually, it's a 2 digit on the drivers door jamb. I was happy with the paint I got and they also have some sort of gaurantee.sigpic
1986 Grand Marquis LS 2 Door
