Can anyone tell me why the low beams get bright and then dim when I turn on the high beams on my '88. I can see so much better when the low beams are brighter. They'll stay bright if you hold the flash-to-pass. Dose that make sense to anyone? It seems to be common on the late-80's Ford's I've driven.
It's annoying, especially when teh old '82 didn't do it. I guess something is sucking up the voltage when you let up on the flash-to-pass. Does anyone know how to stop the dimming?
