Replacement Headlights
    OK, how do you relay the headlights? Sounds like a good idea, so why not do it.
      Pretty simple. You use the power supply wires for the headlights as activation wires for the relays, and then use the other side of the relay to actually power the headlights.
        it's easy just check the other threads for the wiring digrams your should relay the headlights it will save your headlight switch
          Word of warning:
          In Ohio at least, you can be busted for running "any more than 5 white lights" on the front of your car. I got pulled over and got a verbal warning in my '88 (my first 'Vic) by the local cops here in Navarre.
          My buddy said, "God-damn! Those (4 fog) lights make it look like there's an airplane landing behind you!"
            Thanks Nathan! The dia. makes it look easy. I'll have to try that.
