Header panel removal
    I was wondering if anyone has any tricks/advice for easily removing the front headlight, grill header panel? It seems like the three bolts on either side are virtually inaccessible.
    I got frustrated with it, and broke away the fiberglass with a pair of vice grips while trying to remove a fender in a junkyard.
    Obviously I don't want to do that to my car. Any help would be appreciated. Thanks.
    you gadda use an asortment of swivles and extentions to get to them. and you also have to remove the battery and washer fluid tank.
      Reach around into the fender after moving the battery on the one side, and the washer fluid tank and crap on the pther side. Protect your wrists and fore arms when doing it, or else you can get cut up a little bit. There should be two or three morein the middle of the car I think) below the hood ornament. Just take your time and don't get pissed off.
