rusted rockers
    rusted rockers
    is there a place that sells rocker panels for
    a 87 cv wagon my are rotted
    doubtful... i need a pass. side for my Grand Marquis and a driver side for my CV
    Addicted to 86-87 Panthers
      Your local metal shop will be able to make some, or you can got to a junkyard.
        i would rather cut them out since they collect debris anyway.
          cut em out and it'll leave a hole all the way up the a,b,c pillars...Not a good idea, if they are soild they dont collect debris.
            JC Whitney carries a lot oddball patch panels, you might check with them. Quality usually sucks, though. Otherwise, junkyard like the others said.
            On teh wagon, I scuffed them a little, bondo'd the thin spots, and reinstalled the moulding after paint . Not recommended for a car that you actually want to be nice, though.
              Cut it out, weld a panel in, bondo it smooth.
                Just make a patch. It isnt that hard, just time consuming. Nothing a vice, tin snips and some hammers and dollies cant make. That is how I make mine when I have to do rust repair in the shop.
                  All I'd add was to make sure you use a decent filler like USC All-Metal over the patch, it's stronger and offers greater corrosion resistance.
                  1986 Grand Marquis LS 2 Door
                    anybody got an exploded view of rockers
                      Come again?
                        when parts are apart in a drawing piece by piece exploded
                        i would like to see how the rockers on my wagon are put on
                          its part of the body as far as I'm aware, they aren't really "put on" in a traditional way with nuts and bolts and such. There probably is a weld somewhere involved but thats really it.
                            ok most likely spot welded thanks
                              Dunno if this will help you any since mine isn't a wagon but it should be relatively similar.
