Sedan delivery style wagon, aka metal over the rear side windows...
    I have been tinkering with the idea of covering the side rear windows of a wagon with metal/fiberglass/??? and blending it in, so it looks like there never were windows there to begin with.
    I had a box hearse once but they just pop riveted some nasty galvanized metal right over the glass and hid it all under the vinyl top. The other side of the glass had headliner material glued right to it. It looked great on the inside.
    Has anyone got a picture of a wagon done like this? Real or photochopped doesn't matter.
    Opinions?
    Axle codes
    Open/Lock/Ratio #
    G / H / 2.26
    B / C / 2.47
    8 / M / 2.73
    7 / - / 3.07
    Y / Z / 3.08
    4 / D / 3.42
    F / R / 3.45
    5 / E / 3.27
    6 / W / 3.73
    2 / K / 3.55
    A / - / 3.63
    J / - / 3.85
    would be neat. Never seen one done like that though. Just get like 50 gallons of bondo and put it over the glass...
      It would be pretty easy. I would pop out the windows then weld in a sheet of metal to do it properly.
        I think it'd be almost impossible to get it to look straight. But it'd be cool none the less. Even cooler if you hid the rear doors and windows too.
          Opera windows! Opera windows!
            you'd have some killer blind spots!!!!!!
              That is true. You could roll a couple of beads in the panel to add to the strength and looks of the panels.
                It Can be done...look at the way panel truck conversions have been done in the past...they got it to look straight so can you with the proper prep work first. I would roll a few beads into the metal sheet you will be using and the cut it to be a little bigger then the glass and then weld it up there...the use some Allmetal filler to even it out in the edges...then use plastic filler where it's not straight.
                  I think it would look awesome if you could pull it off. It would be like a Slicktop Hearse!
                  No need to roll beads into it to get it to look straight. Just cut out your smooth flat sheet metal piece in the correct shape, and then build some interior braces to Tack on to the inside of the piece for strength. Weld your piece on w/ the braces on the inside, weld your braces to the inside structure of the body, smooth out the exterior sheetmetal warpage with Filler, Prime, Shoot a Guide Coat to make sure every thing is Completely Flat, Paint'er up and your done. With some hard work you could get it to look completely straight, its been done before.
                  There is a guy on Cardomain that actually made his LTD CV Wagon into a Hearse. I think he just Covered over the rear windows with the Vinyl Top though.
                    I think it could be made to look decent with lots of work. What Zwack said about putting beads in the panels is also a good idea.
                    If IO was going through that much work, I'd make it a two door; and not like that other hideous two door that someone posted on here. Get the doors from a two door and make it work. Now thats a project.... far too ambitious for me.
                      could just paint the windows
                        That would be even better, a true custom! Of course you'd also have to have the front extended part of each rear QP w/ the small window, which covers the part were the half of the rear door would be on a sedan.
