Was under S.U. tonight. The usual surface rust is pretty much everywhere. Nothing seems to be anything of a major issue, at this point. What is a good way to go about an underside restoration without removing the body from the frame? Strip down everything and undercoat? Prime/paint? I'm talking about the whole works ... fuel lines, floor pans, trunk floor, frame, rear axle, etc. What would be some good tools to use for this job? Thinkin' I may wait 'til next year when I get an air compressor and attachments.
complete underside restoration?
wirebrush and por15 all the bare metal......i'm not sure about por 15 over the surface rust on the painted floor pans.....check their website
POR 15 will go right over rust, IIRC. If you want another option; 3M rocker shutz (yes that is the name). Its stone gaurd. You need a special gun (less than $75), and a compressor. You can paint it after too. Its really durable.
I personally would do the sand, prime paint. I like the smooth surface look. Good luck, as I think this will be a substanial project.**2012 Ford Mustang Boss 302: 5.0/ 6 spd/ 3.73s, 20K Cruiser
I spent the weekend sandblasting under the wagon to clean up the brake and fuel lines. The supply side fuel line basically vaporized (it didn't even leak before!). I don't recommend sandblasting a car on the frame!
The problem with undercoating is the rust continues to grow under it. If there is no rust to begin with, it's great.
I'd take a wire brush on a grinder and open up the rust. Get some "Rust Converter" paint and paint all the rusty spots. This probably means brushing some because it is hard to get to all of the frame and lines with the spray. Then top coat with two coats of paint (or one coat paint, one coat undercoating).1990 Country Squire - under restoration
Originally posted by lincolnmania View Postwirebrush and por15 all the bare metal......i'm not sure about por 15 over the surface rust on the painted floor pans.....check their website
Originally posted by P72Ford View PostI personally would do the sand, prime paint. I like the smooth surface look.
I may, however, put this off until next spring. That is when I hope to have the money saved up for a nice air compressor and attachments. This would also allow me to do a much cleaner job of painting/undercoating the car since I'll also be getting a paint gun. I'm getting tired of messing with rattle cans.
Originally posted by saiyaneye View PostWhy not sand blast, I know it can cause panel warp, but who cares about floors? Just wondering because I want to sand blast my trunk floor.1990 Country Squire - under restoration
Originally posted by saiyaneye View PostThe trunk floor is pretty clear, not too much stuff I can accidentally hit right? I really want to do this w/ rubberized undercoating to help with sound deadening.1990 Country Squire - under restoration
