Well,I won't say that it's necessary,because you could mess around with it all day,taking the door on and off,adjusting the hinges one at a time,basically Trial and Error until you finally stumble onto the correct alignment.I would just say that it's the proper way to do it,(I like to do things the right way,which is usually the hard way).
To do the job properly,The door needs to still be installed on the car with the Striker Pin Removed,then the door held fully closed and the body bolts on the hinges loosened just enough so that they barely move,once the door is lifted/pulled in the desired direction (for Example UP) both hinges will sag a little and must be moved in Unison the exact same distance (Up),taking your time,to keep the geometry of the hinges exactly the same as before.Even a little off and the door will not shut correctly,and will dramatically reduce the life of the Hinge Pins.
My car is very mint as far as being rust free,so it wasn't really much work or annoyance for me to get everything done,even doing the entire disassembly,alignment,and,reassembly by myself.I fixed a few areas where rust was just starting along the way,one was under the front windshield on the Cowl,
,glad I caught that before it got worse.From the time I got started to teh finish,I only have 6 Hours in the Project,and that was taking my time to enjoy it as I went,I enjoyed every minute of it too.
