Took the interior out of the brown merc to fix "one" visible rust spot, Well after removing the whole interior i found a hole lot more that was hideing you couldent see it from the bottom sice its all undercated and looked fine,
The floors are petty rough but im willing to spend the time on them and do them right since the frame and the rest of the car are in great shape, abd it drives like a dream,
so this thread will be my repair progress thread
on the weekend i gutted the interior then went out and baught 2 sheets go good heavey sheet metal, nd some cutting wheels for the die grinder to cut the infected areas out
tonight i got the frt pass side floor all welded up(no pic of that yet, i forgot to take one before i came in) , and started cutting all the infected metal away to make it cleaner now just have to do the rest after its all fixed the floors will be painted inside and on the bottom, along with the frame and all,
Here are the pics, i Know it looks bad now but every pic from here on in it will start to look better, good thing i love panthers, atleast another will be saved from the dead, and i have fixed floors worse then that
This is how you tell if your car is canadian, lucky my 2 door floors are solid
Will have more pics up tomorow with more progress,
