Can this be done? This is the situation; I got the body filler all smoothed on the pass. post of the Ranger I got. I masked everything off on that side and applied primer. The first problem was a fly landed on the primer just as it was got tacky. I wasn't sure what to do so I plucked it off, which left small craters. I figured that I would let it dry and wet sand it; but when I got into the house I realized that I bought the wrong can of primer. It says on the can that sanding non- sandable primer can result in gouging (or it lifting off of the surface) the primer
. Is there any way of getting around this, or do I have to somehow strip it off and start all over again? Thanks for any help that you can give me
