i got alot of little door dents...i was wondering if anyone knew a way to pull them out without costing $300 a door like i was quoted...and does the ding king actually work?
dents!
I had a friend that said it worked but I never used it before. So I wouldn't know.
Basically you have to either get a PDR kit which will probably be expensive plus you would need to learn how to do it. Or you can sand the doors down and use filler on them if they are a 1/4" or less deep, if not you need to use a hammer and dolly to work them out first.2000 Mustang GT "Blondie", 2000 CVPI "Sargent Crusty"
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
Originally posted by zwack88 View PostOr you can sand the doors down and use filler on them if they are a 1/4" or less deep
Originally posted by Nathan in MN View PostI'm highly hesitant to question a college-educated body mang seeing as I know very little about body work, but isn't 1/4" awful deep to be putting in body filler? I thought 1/8" was the max for filler.1987 Country Squire LX Wagon 5.0L: Daily Ride......1964 Lincoln Continental 430ci: Toy #1.
Yeah 1/8th inch is better but todays fillers are far superior to the ones from even 10 years ago. They stick better, flex better and are sand better then the older ones. So ya a 1/4" is acceptable.2000 Mustang GT "Blondie", 2000 CVPI "Sargent Crusty"
