See my photos, the top section of the front grill on my 88 Town Car is blocked off, looks like it was definitely OEM, why would they do this? I did not eyeball measuring and it appears air through this section would reach the radiator? I'm always looking for better cooling where I live....
88 Town Car has some of the front grill blocked off? Looks factory.....Why?
2 Photos1984 Mercury Colony Park Wagon - 393 Dart block LS 91mm turbo with 4L80E and 9" 6.24@115 in the 1/8 mile (9's in the 1/4), 4650lbs w driver, AC, Drag n Drive rig 1300hp
1988 Lincoln Town Car - stock for nowTags: None
I think there was a thing about the radiator being too much in colder climates so that was used to help the car stay warm in the winter.
- Likes 1
My 88 and 90 Fords both have something similar. Figured it was an aerodynamics thing. No factual clue, however.1990 Country Squire - under restoration
If it's for cold climates it's gone, if it's aero, might leave it. I think it might be aero, just like air dam prevents so much air from going under the car and creating turbulence and lift hitting all the suspension , oil pan etc... But for my needs might just ax it to get better cooling for my future plans....1984 Mercury Colony Park Wagon - 393 Dart block LS 91mm turbo with 4L80E and 9" 6.24@115 in the 1/8 mile (9's in the 1/4), 4650lbs w driver, AC, Drag n Drive rig 1300hp
my 86 is blocked in the same way. Never had any issues with it running hot.86 Lincoln Town Car (Galactica).
Originally posted by drhill View PostIf it's for cold climates it's gone, if it's aero, might leave it. I think it might be aero, just like air dam prevents so much air from going under the car and creating turbulence and lift hitting all the suspension , oil pan etc... But for my needs might just ax it to get better cooling for my future plans....What I Own: 1993 Mercury Grand Marquis GS
- Likes 2
