My drivers side backup warning bulb is out, and I have to get the car inspected this month. But I cannot see for the life of me how to get to it? its behind a solid chunk of iron. Is there some trick to getting the light bar out or something? thanks!
uhh the backup warning light bulb is WHERE??
You can get them out no problem - get under the car and look right under the backup lights, the bulb sockets are pretty massive, white (not taking mud into account), and come out with twisting and then pulling out, just like the front marker lights. You can actually reach the sockets without even crawling under the car, just reach under and right behind the bumper, and removal of the light bar is not necessary at all.
Sweet I just checked that out! thanks mang!1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
