I've been looking into getting fog lights for my car. I'm going to mount them on the bottom of the front bumper. Not concerned on looks, just a set of lights that work well especially in the rain.
Driving/Fog Lights
Driving/Fog Lights
Associated Panthers:
http://www.cardomain.com/ride/2128327Tags: None
they say amber lenses do better in the fog and snow, and have less glare than white lenses.Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
auxiliary lights should NOT be installed under the bumper, the first steep driveway you go through will take them out hardcore. Install them above the bumper, behind the grill, or if you wanna be badass cut your bumper up and install them in there. My fog lights have clear lenses but amber filters on the reflectors, as a result the light is amberish in color and works very well in snow and fog. Also the 55W stock crappy bulbs are now replaced with Sylvania's 100W offroad bulbs, and they do make a difference
Would a set work behind the grill? I think since I have the older grand marquis grill I can only mount them in front of it?
Also, do you have a 3g alternator or can you run those 100 watt bulbs off a stock alternator?Current rides - 1991 Ford Thunderbird 3.8 v6 (gas saver/DD) - New Heads/Headgaskets with ARP studs, Air Silencer Delete, 70mm MAF, Plasti-dipped Matte Black with a Silver Metalflake Overlay, Muffler Delete, some LED's, 30.233 MPG for high MPG average!
I forgot what I was reading...But it said that it doesn't make a difference between the amber and white lenses...If I find it, I'll post a link.
Originally posted by 87mefullWould a set work behind the grill? I think since I have the older grand marquis grill I can only mount them in front of it?
Or you can go really bad ass, and install them IN the grill! Commonly people say that yellow works best. In reality, the physically best light color is green. Green light travels farther than any other color in the visible spectrum.
Yes, below the bumper is a bad idea. Not only will they get removed rather quickly, but being so low makes them less effective. Notice how 4X4 folks put them on top of the truck, it's not because of looks (well, the reason that was started was not for looks).
I plan to upgrade mine as they are not really that bright. Keep in mine that 100watts on 12 volts is about 8 amps.
Watts = Volts X Amps
I always liked the look of the Mark VII fog lights and think they could work well on a GM/CV. Only things are the Marchal fog lights are ridiculously expensive, and people might wanna take them. There are many cheaper look a likes out there. I really don't think them hitting would be a big issue as there are many of cars that are much lower to the ground. Depends on where you live as well.sigpic
1986 Grand Marquis LS 2 Door
Originally posted by 87mefullAlso, do you have a 3g alternator or can you run those 100 watt bulbs off a stock alternator?
