Did some more work on the tudor today. I took off all of the chromed trim along the bottom of the car, and found some rust in the lower quarter panels. Two medium sized spots on the driverside, one on the passenger side. Is there anything I can do now to keep it from getting worse while the car is sitting?
I worked on the paint too, mostly experimenting with the trunk lid. I'm not worried about its condition because it is rusty and needs replacement. I have faded paint and white streaks all over the place from a bad wash or wax job years ago. I've tried a few things but so far nothing was rough enough to remove the blemishes. This time I tried some 1500 grit wet sanding and meguiars medium cut paint cleaner on one section and just the meguiars on another section. Meguiars alone did take up most of the junk but the surface was wavy. The sanded section still had some light scratches but all of the blemishes were gone and the surface was flat. I think the best combination will be 2000 grit sanding and the megiuars.
(Most of the paint looks like the area under my hand)
