If i'm not mistaken the hood and fenders need to be swapped over as well.
Nick
88 Colony Park LS
I'm sure someone else will chime in but I'm about 97% sure that's the case. I bet with some careful dremel work you could make the lights look OEM.
Nick
88 Colony Park LS
