I would personally keep the original tails. I am biased as my 86 has the same ones. The 79-82 tails have smaller lenses, which I'm assuming puts out less light, and the black part always looked like a cheap filler piece to me.Your originals have more lines in them, which I personally like, plus it has classic look that can be seen in some of the newest Mercury designs (Mariner, Monterey, ect). The 88-91 tails are fine, but are made smoother to go along with the redesigned/smoother look those cars have.
1986 Grand Marquis LS 2 Door
I like the original ones a lot better. I think having more of those silver lines makes it look a bit more stylish.
1984 Grand Marquis GS - CFI-SEFI conversion, Explorer 302, GT40 intakes, GT40P heads, 1.7 roller rockers, HO Cam, ASP Underdrive Pulley, 2.5" Dual exhaust, Flowmaster Delta 50 mufflers, 3.55 Trac-Lock, Rear disk's, Moog cargo coils, ES rear poly bushings, PI front and rear sway bars, 3G alt., Mark VIII fan, custom Auto-meter dash 1990 Crown Victoria Country Squire - Explorer 302, HO cam, dual exhaust, 3.55 Trac-Lock, PI rear sway bar (SOLD)
I'm a fan of the originals, but the others aren't bad if you want to be different. With the early grille, then most people won't be able to tell your car is an '84 instead of an earlier model.
im happy with my stock ones on my 81 2door, but if i had an 83+i wouldent change em, i say leave it how it is, looks good!
