Well you described a conti kit type one, with the ring and....ah forget it....
You don't see that too often ;)
Not quite, conti-kit has a fiberglass cover with a narrow stainless steel strap (or ring) around the cover's circumference, the fiberglass cover has an opening at the center through which you can see the spoked rim. SUV-style involves a flat aluminum or vinyl face that goes over the wheel's flat side (sidewall and rim), then an aluminum or stainless steel ring as wide as the tire itself to cover the thread. Conti-kits hold only one size of wheel there (205/70-15 IIRC), SUV-style are adjustable to some extend.
2 words
junkyard van
