Here I plan to detail the process of removing a vinyl top, and document everything as I go.
I'd like to make sure I have all the things necessary before starting, so if you can think of anything to add to the list, please do. Here's what I'm pretty sure I'll need:
- Adheasive Remover
- Sander + Sandpaper
- Grinder
- Fiberglass Body Filler
- Primer
I'll probably stop by Lowe's on Sunday morning as I get off work and pick up the adheasive remover. I have an air grinder already (cheap-o from Wal Mart). I'll need to pick up some body filler as well, and I'm hoping to borrow a sander.
I know the rear window trim will come off with prying with a screwdriver, is there anything else I need to know? I'm going to leave the metal trim on the roof for a while, until I'm able to have a friend weld it properly. The vinyl will come off with that trim in place, correct?
Anyway, please post comments or questions here. Feel free to sticky this, or not. I'll update it as soon as I have something to update.
- Adheasive Remover
- Grinder
- Primer
