I need a scan of the Premium sound radio pages for an '88 Grand Marquis sedan. My friend has just bought an after market radio, but I can't figure out the speakers. I have the power ground and switched power all sorted out. He doesn't want to run new speaker wires, so how can I get it to work with the original wiring and amp?
Need someone with an '88 EVTM
get your friend to spend $15-$20 on a roll of wire from walmart to run new lines for the speakers. the wire adapter/harness for after market stereos doent work with the common ground setup. i buy the harness/adapter to power the stereo and buy a roll of speaker wire and run new lines to the speakers. if your friend wants affordable speakers, might i suggest the speakers you saw in Baby during SF07. they are the Dual illumninites that can be purchased at walmart. the speakers still sound as good as the day i bought them and are impressive for the price. the lights on them dont have to be hooked up, but the speakers are about $35 a pair for the 6 1/2 and the 6x9s. i dont like hooking up the dash speakers since the dash on Panthers are fragile.
Originally posted by 87_crown_vic View Postget your friend to spend $15-$20 on a roll of wire from walmart to run new lines for the speakers. the wire adapter/harness for after market stereos doent work with the common ground setup. i buy the harness/adapter to power the stereo and buy a roll of speaker wire and run new lines to the speakers. if your friend wants affordable speakers, might i suggest the speakers you saw in Baby during SF07. they are the Dual illumninites that can be purchased at walmart. the speakers still sound as good as the day i bought them and are impressive for the price. the lights on them dont have to be hooked up, but the speakers are about $35 a pair for the 6 1/2 and the 6x9s. i dont like hooking up the dash speakers since the dash on Panthers are fragile.
There is an amp bypass kit, and a stereo install kit that allows you to just plug into the stock wiring. Go to a place that sells that stuff, and they should know what you're after. Don't cut any of the stock wires.86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View PostThere is an amp bypass kit, and a stereo install kit that allows you to just plug into the stock wiring. Go to a place that sells that stuff, and they should know what you're after. Don't cut any of the stock wires.
premie sound
i have a 87 wiht premie sound too but i used to install professionally i havnt hadf a chance to play with mine yet but i know that you can get the back ones to work on factory wiring the front ones you migt have to hardwire when i get a headsunit ill play with it and see what i can come up with just to let you know the amp does have a turn on that you might have to hook up to the blue wire on the head unit i havnt tried it yet but ill let ya know when i do. i know this system is diffrerent form my 85 so it will be fun to play with it. good luck mang89 townie, mild exhuast up grades, soon to have loud ass stereo....
Originally posted by zoomie View Posti have a 87 wiht premie sound too but i used to install professionally i havnt hadf a chance to play with mine yet but i know that you can get the back ones to work on factory wiring the front ones you migt have to hardwire when i get a headsunit ill play with it and see what i can come up with just to let you know the amp does have a turn on that you might have to hook up to the blue wire on the head unit i havnt tried it yet but ill let ya know when i do. i know this system is diffrerent form my 85 so it will be fun to play with it. good luck mang
