This is kinda wierd but when I have my AC on and the gas pedal half or more down my car switches for blowing out the vents to blowing out the defrost. I'm assuming it has to do with vacuum but where should I look?
Auto switching vents :drug:
Or, if you have auto climate control with the thermal blower lockout thing, the vacuum connector there could be leaking. Definite major vac leak on the climate control's vacuum source tho.86 Lincoln Town Car (Galactica).
get a plastic one!!!!!!!!!!!Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
Originally posted by turbo2256bMy vacuum can was rusty found a hole in it and plugged it with some wind shield butil rubber stuff. Started the car and watched the can implode.
1990+ I think had the plastic one. Its on the driver's fender with a relay box attached to it. It looks like some sort of electronic thing, but its really not. Look for the ECM relay, and thats the vacuum reservoir.86 Lincoln Town Car (Galactica).
