Well I'll see how the changes I made tonight affect things. I now have the vacuum source going straight to the EGR solenoid and then straight to the EGR valve. The rest of the lines going to the smog pump stuff is unhooked. The small canister on the right fender is unhooked too. I was going to leave it but I didn't have a vacuum splitter...not sure which part (smog or EGR) it was meant to work with?
Vacuum Elimination?
Originally posted by PushnFords View PostWell I'll see how the changes I made tonight affect things. I now have the vacuum source going straight to the EGR solenoid and then straight to the EGR valve. The rest of the lines going to the smog pump stuff is unhooked. The small canister on the right fender is unhooked too. I was going to leave it but I didn't have a vacuum splitter...not sure which part (smog or EGR) it was meant to work with?
Down by the battery? If so, that's part of the EVAP system. It recycles the fumes from the gas tank into manifold vacuum so the motor can burn it. I believe the idea behind it is to keep the pressure down in the fuel tank. If you leave that unhooked it will vent those fumes to atmosphere wherever the canister itself is. Mileage might be worse since the computer is correcting for the (small) amount of fuel it's not seeing burned
If it's not the evap thingy then forget I said anything.sigpic
Originally posted by 1990LTD View PostDown by the battery?
What I assume is a vacuum reservoir that I unhooked is on the rear of the RH inner fender and held down by two tabs with plastic clips.
Leave the EVAP system hooked up. What happens if it doesn't work is that the pressure will build in the fuel tank until the gas cap reaches its preset limit and vents all of those fumes into the atmosphere. Which stinks, and may get fuel on the car's paint. Also, the computer is expecting the fuel vapors coming in through that system and it might run worse if it doesn't have them.Originally posted by gadget73There is nothing more permanent than a temporary fix.
you can actually just unplug the smog solenoids entirely. it sets codes, but so does having them there but not plumbed. Doesn't make any difference to how runs.
evap and egr systems are useful to have. They hurt nothing, and can buy a smidge of fuel economy. win-win IMO. the smog pump on the other hand is a useless waste of space.86 Lincoln Town Car (Galactica).
Originally posted by 91waggin View PostLeave the EVAP system hooked up. What happens if it doesn't work is that the pressure will build in the fuel tank until the gas cap reaches its preset limit and vents all of those fumes into the atmosphere. Which stinks, and may get fuel on the car's paint. Also, the computer is expecting the fuel vapors coming in through that system and it might run worse if it doesn't have them.
