Ain't that fuckin' special? I had some headlight issues, mainly flickering or flashing on and off, mostly the latter when I had high beams on. I pulled the lil fucker out, played around with it (ohh this sounds dirty) and ended up losing dash lights....pulled it out farther and saw that mess. :guns:
Hmm, I guess that would explain not having dash lights...
Ain't that fuckin' special? I had some headlight issues, mainly flickering or flashing on and off, mostly the latter when I had high beams on. I pulled the lil fucker out, played around with it (ohh this sounds dirty) and ended up losing dash lights....pulled it out farther and saw that mess. :guns:'89 Ford LTD Crown Vic - '92 Ford F-150 Custom -
'95 Ford Bronco XL -
sigpic :rebel:Tags: None
mmmmm corrosion.86 Lincoln Town Car (Galactica).
Re: Hmm, I guess that would explain not having dash lights..
Originally posted by BoxMangAin't that fuckin' special? I pulled the lil fucker out, played around with it ....pulled it out farther and saw that mess. :guns:Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
