I'm looking to add ac to my factory non ac car. I have questions that hopefully some of you can answer. Here they are: -Will I need to pull the entire evaporator box out of the parts car or can i just take my evaporator box thats already in my car that was plugged off from factory and put the evaporator core inside (is there any hardware in the box that actually holds it into place)
- Since this is an R12 system where did you get your retrofit kit for r134a
- what type of oil did you use once you retrofitted (mineral oil, PAG?)
As far as the ac components, I plan on buying brand new equipment, the parts car is mainly utilized for the brackets, wiring, and any related hardware.
Note i will be using something similar to this https://www.amazon.ca/VIVOHOME-Manif...s%2C108&sr=8-5
plus a scale and I shouldn't have a problem aquiring r134a
If you can answer my questions or add on to anything in this topic, it will be appreciated, thanks
