Hello all, I am installing some Holley Terminator X into my 89 MGM. I have a few questions about the FACTORY wiring so I can terminate what wiring I don't need and keep what needs to be kept.
Sofar, I have eliminated all the EEC wiring and connectors, but my main concern are the 3 relays and there wiring located on the driver's fender. I know one is a fuel pump relay, but I am unsure what the other 2 are.
So my questions are:
1. What are those 3 relays?
2. Since I no longer need the fuel pump relay with the Holley kit, can I just eliminate the whole wiring for the OE fuel pump relay?
3. If I need those 3 relays, who has a wiring diagram so I can determine what wires are needed and which are not.
Thank you all in advance, I look forward to your response! Others with Holley EFI installs PLEASE chime in too
