View Post
Wipers and horns
If you order the one plug motor for '90-'91 it should come with the right mounting plate. If you order for a '98 it is considerably cheaper but you have to swap your mounting plate from your old motor to the new motor.
In both cases you'll need to grab the wire connector, lop off your two connectors, and splice the single connector in place of the two.
If you've never replaced an aero/whale wiper motor, it's a bit of a pain to get at, compared to a box, to get that wire connector.Vic
