Hi Lutrova,
the six-pointed piece is a push in locking star washer. Just use your dental pic and gently pry up on the tabs. It will come loose. Thereīs not much tension.
Just finished a bench test of the reassembled sensor. I had hooked it up to my electric vacuum source and my spare HVAC plenum box, so I can watch the actual servo motor move.
Results:
Sensor doesnīt work at all. So itīs worse then before. It appears that the sensor bimetal has either lost its tension (need to disassemble again and check the bimetal alone with heat and ice spray) OR the stem I had cleaned the tiny grooves actually needs to seal tight - NOT bypass some air.
Like you said - they all tend towards full cold. But isnīt rubber prone to harden over time? I donīt think the orange seal had softened but the bimetal lost tension. Isnīt this what happens to all these choke springs - they loose tension over time, donīt they?
Please do remove the star washer and look inside yours. Maybe I lost a part undernetah the orange rubber diaphragm (which I doubt). Maybe there should be a rubber seal that had disintegrated on mine and had been rinsed by the ultrasonic cleaning.
Reassembling the spring works smooth if you use two arterial clamps. One to hold the spring end in place, feed it through the hole and the other to grab the extruded end once itīs fed trough. Make sure to unscrew the setting screw at the bottom end. I took pics but need to upload.
Results:
