Hey guy's, been a little while.
I put the car (1987 TC )back on the road this month after being in storage for the last 6. Been doing pretty good but I've got a little starting problem that's happened about 4 times so far while daily driving it to work and back. I don't know if I need to get a new starter or if I need to pull it apart for cleaning... Or if all I need is another solenoid.
Here's what it's doing. Every so often I turn the key to start and the starter just spins. It does not engage and turn the engine over. When ever I've hit it a second time it engages and turns the engine over. When it turns the engine over, it turns it fast. Doesn't happen very often, like said above - it's only done it 4 times in the week I've had the car back on the road. Doesn't seem to matter if the car is cold or hot. I've had it just spin on both occasions .
I'm not sure how these starters are set up. Do they have a bendex type gear that is spit out into the flexplate by the spinning motor? Do they use a solenoid to spit the gear out into the flexplate? I don't know. I have no experience with these. What's it sound like to you guys, and what am I looking at doing before I just go and buy another starter?
