So one thing I have noticed about V6 3G units is they run a larger pulley than the V8 cars. I’m considering swapping mine out to a smaller one on the ‘87 due to only semi-adequate output with a lot of accessories on and the car warmed up in gear.
With the pulley size change, I know the current belt won’t fit, and the stock size might actually be correct again. Just a thought to retain the 130 amp unit without having too much travel on the adjuster. Mine is in a similar boat with the adjustment almost all the way out.
