The other day while driving my 85 TC just died in the middle of the road. Had been driving for about maybe 3-5 minutes after startup (cold start).
Cranks all day long but no fuel. I don't here the fuel pump running at all. I will not hear it prime or anything. Fuel pump was replaced about 2 months ago as the original had some dryrotted rubber stuff on the assembly that was causing issues.
I have tried replacing the pump relay and the EEC-IV relay to no avail. I checked the inertia switch its not tripped. I am getting +12v to the fuel pump relay on both the control and load side. The relay does nothing. No click or anything.
I have tried grounding the fuel pump test port on the obd1 connector as well with this also doing nothing. This has started to get quite confusing. I have checked the pump for resistance and it has a few ohms resistance so its not open. While jumpering the fuel pump test port to ground I tried measuring voltage at the pump connector. Got nothing.
About a week ago I had it die on me just like this except in that case it started right back up.
Any ideas folks.
Any ideas folks.
