I like the sound of the older starter. Plus they're cheaper.
Lmr 130 amp kit
Originally posted by Mainemantom View PostI want to order this kit for the 89 TC. The question I have is this: Is the alternator bracket for a 302 Mustang offered in this kit compatible with the TC bracket ? Has anyone used this ? I want a total plug and play mod. Thanks[ATTACH=CONFIG]56069[/ATTACH]
That kit will definitely provide everything else you need though. If you really wanted to avoid cutting on your factory harness very much, you can even re-use your existing voltage regulator plug. Just gotta cut the white stator wire and splice on the new single plug connector from that kit to it.
My Cars:
Skip the bracket wont do you any good.~David~
At most, you'll need to clearance the inner lip on the lower bracket. That's all. Takes about 5-10 minutes with a grinder. Maybe 15 with a die grinder.
I must be the only person with a 3g and an intact alternator bracket86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View PostI must be the only person with a 3g and an intact alternator bracket
My Cars:
Same here, I left my brackets alone on both, although I can see how it would help to grind that bracket down a little especially if you have a larger pully on the altenator.Vic
