Light on the salt?
not sure I understand. In stock form the signal side is grounded through the threads. The heater side grounds through the connector. There is also a wire in that harness that needs to ground to the block. If someone has pulled the O2 heater grounds out of the harness and tied them to the block, that should still work but the SIGRTN wire in the O2 harness must be connected to ground as well.86 Lincoln Town Car (Galactica).
