If they do where is the hazard unit and what does it look like?
do the boxes have 2 flashers? turn and hazard?
12 Escape Limited V6 AWD, 225/65R17 Vredestein Quatrac Pro, Winter 235/70-16 Conti Viking Contact7 Mods>Beamtech LED headlight bulbs, Husky floor linersTags: None
Yes. The hazard is on the back side of the fuse panel, looks just like the regular one.86 Lincoln Town Car (Galactica).
That explains it.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
Some of the flashes have a different value. Could flash faster or slower depending. And one or both of them may be plastic instead of metal.
Also take mental note of the orientation when you remove the backside one.. can be a bitch to get it back in sometimes. The fuse panel plastic may crack on you depending on condition. ForwarningCharlette - Brown 1977 Ford LTD - 351 Windsor 155K, Full Custom Pioneer system, green HID, interior & underbody
Alesha - Black 1982 Mercury Marquis - 255ci 178K, full custom Kenwood and Infinity system, lowered, dual exhaust, LED all the things
Tangerine Dream - Orange 1988 F-150 Custom - 300 i6 82k, Ghetto sound system, 5spd, 2WD, #farmtruck
Originally posted by knucklehead0202 View PostWeird i didn't know this. Had to change my flasher when i put in new LED taillight bulbs but the hazards still work normally. Huh, learn something new every day...
knucklehead did you change front and rear? Also if i understand correctly some bulbs have resistance built in, defeating some of the reason for having leds.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
I retain standard bulbs so I can keep the original bi-metal flashers. They make the right noise. I actually rolled several through the Continental to get one that produced the right flash rate and tone.86 Lincoln Town Car (Galactica).
