I have installed aftermarket remote locking mechanism in my '87 Grand Marquis. It is compatible with reverse polarity lock system and I wired it according to instructions provided with it. Locking and unlocking the door using remote keyfob works fine, so does trunk popper. But the buttons on the driver and passenger door stopped working. When the remote control unit is disconnected, door buttons work fine.
Any ideas what could cause this? I assume I wired it wrong somehow. The wiring info at https://www.the12volt.com/installbay...tail/1476.html shows lock/unlock wires as pink/yellow and pink located in driver's kick panel. I could not find any purely pink wire. Driver's (un)lock button controls the locking via pink/yellow and pink/green wires (located near the driver's door in a connector near the parking brake pedal) so I wired the remote control unit's lock/unlock wires to them. Is there any other place where should I tap the wires instead?
